Sorry for the pause in replying, appreciate your response! First thing I did was cleaned the tank, had some minor rust, but cleaned up well replaced the fuel filter while I was at it. Second, checked the fuel pump, had some corrosion there as well, the diaphragm was still intact, so cleaned it up and put it back together. Seems to be working, but did not check pressure or flow volume. The tank has a strong vacuum and gasps when the cap is removed, should I replace the gas cap? This stll leads me to believe there is a good chance the carbs may have ingested some of the debris. Time for a carb rebuild? Your thoughts!
