I have a 1983 Goldwing and I need to sync out the carbs. Does anybody know off the top of their head what the vac specifications the carbs should be running at? Also how do I adjust the carbs so that all are lined up?
Welcome to the forum. There is a GL1100 carb sync thread somewhere here, but I can't find it. You should pull it up with the forum search.
To get you started, here is the one for the GL1200, it has a video on the page too.
http://www.goldwingfacts.com/1200balancecarbs.htm
I think the only real difference with the GL1100 is that the fixed base carb is #3, on the GL1200 it is #4.
the numbers don't really matter, just adjust so 1&3 are the same, then 2&4, then 4&3. I recheck after, to get it as close as i can. good luck!
