JCWhitney sells some replacement mirrors that are pretty good replicas.. I have a pair that are not installed that I bought for the same reason.. However, if it is just a matter of tightening, I've had great luck with using thread locker on the ball, so much so that I have put off installing the new ones... The green stuff (the kind that flows into the cracks after assembly) works well, although the blue can be worked into it also... and even RTV has provided results.. after time.. a month or so.. as you move them they eventually get looser, but a repeat of the locker fixes it..
