Hi, I'm finishing off a project on my new 1984 Goldwing GL1200 Aspencade. I want to replace the battery leads but don't know what amperage rating for the cables. Can someone help with this information please as I can't find it in the Workshop manual.
Thank you
any auto electric rebuilder in your area should be able to tell you what gauge cable is used if you take the old cable into them
i used a piece of welding cable i had sitting around with some cable lugs and used a crimping machine
If you have the old wire, buy a cable that is one step thicker. If there is no room for that, stick with the same size. As long as it is a flexible automotive wire, it is fine. Welding wire is fine, they are very flexible, and has low resistance.
Remember that copper is very expensive for a manufacturer, so they has choosen a wire that is as thin as possible. That's why going up one size can sometimes give you some benefits.
16mm2 multi stranded copper wire should be fine. I think that's equivalent to 7 SWG or 5 AWG.
