1 - 20 of 23 Posts
I have a 1984 Aspencade that cylinders 3&4 stop firing above idle. All wiring and coils have been checked out. Pulse generators both at 10 not 12 +\- 100 as per specs. Is there a way to check the output of pulse generators?
Yes the PG's should be about 1 volt AC. Does it help if you add choke when it is acting up?
No. Bike starts, revs a bit (no spark on 3&4 checked with timing light) slows to idle and spark appears. Bike runs on 1&2 at higher RPM. I've had thoughts of one side PG failure. Can you give me details of checking PG for AC?
Did a bit of research re AC check. Mine is not good, very low to 3&4. Ordered, used of course, off ebay. Thanks for the suggestion.
Could flip flop the coils just to be sure if you want.
So 1&2 were in the 1 VAC range and the 3&4 were low especially at higher RPM?
1&2 weren't all that great (below 1) but 3&4 were definitely low like .2 or so. 3&4 stopped firing much above idle with the timing light. I don't have a specific figure but know it just quit firing. Timing light indicated steady firing on 1&2. With the AC test, 1&2 bounced around below 1 but 3&4 were definitely bad. I've been messing with this bike for a while but never did the AC test. I'll install the used PG and see if things are fixed. I got new coils, plug wires, ends, as well as a different ICU, etc last summer. I'm an old man (pushing 80) and use this as a project. Like to tinker with things. I've got another 84 I ride. I didn't check the AC at different RPMs. I've seen the AC test mentioned before but your comment motivated me to get it done. I've been suspicious of the PG all along.
02 GL1800 w/Auto Pilot
the ONLY valid test is the A/C test between any two of the 3 windings.
should be 50-70 VAC at 3,000 RPM. With the yellow wires cut loose from the harness. Open circuit voltage test here.
forget the ohm meter, except looking for a Short to ground/frame of the stator. That is the only valid ohm meter test, looking for shorts.
Discussion Starter · #8 ·
OK
John, I think you are talking about testing the stator. He is testing the output of the PG's. Right church but wrong pew. 😎
Discussion Starter · #10 ·
I recognized the stator test. Just wasn't quite sure how to respond so I just said "OK".
duh,
guess I have a sunstroke going on..... hotter'n blazes in Eureka Springs, AR.
Discussion Starter · #15 ·
John,
At our age we are allowed more than one mistake..For you, that is number one. 🆒 😎
For what ever it's worth, didn't disturb me at all. Like anyone with yrs on them, my list is long. Not knowing the other person, I just didn't want to offend.
My skin is armor plated :)
quite often, my fingers out run my brain cells.
I call it TypeLexia :unsure:o_O
Check the input voltage to the coils, black/white wire.
Discussion Starter · #20 ·
Dave0430
Voltage of black/white. AC or DC. My first thought was AC but then got to wondering.
1 - 20 of 23 Posts
