1 - 3 of 3 Posts
I'm rebuilding the front left caliper per the manual. I disassembled everything, cleaned all the parts and began re-assembly when I got stumped on installing the dust seals.
The manual says to install the piston seal, intall the piston and then install the dust seal. There isn't enough clearances to install the dust seals after the piston is installed.
I tried to install the dust seals before inserting the piston but it's a very tight fit and I'm afraid to force it an damage the dust seals.
Any help would be appreciated.
· Postpubescent member
:waving::waving:Welcome to the Best Goldwing Site on the Internet amccull!:waving::waving:
Just install the dust seals and the piston seals in their grooves and then the piston. Before you do that though wipe out the cylinder with brake fluid, soak the dust and piston seal and pistons in brake fluid for a few minutes. They should push in with a firm hand pressure after that.
1 - 3 of 3 Posts
