1984 GL1200 clutch master cylinder
2808 Views 27 Replies 23 Participants Last post by  GoneFishin
Hi I have a 1984 Naked GL1200 Just got it ,it has only 1174 miles on it & looks like new
But the clutch is not working, Have tried to bleed it & there looks like a lot of air ,but when you pull the lever there is not a lot of fluid movement
So I think it needs new seals in the master cylinder ??? if so how do I strip it, there is like a rubber boot where the lever plunger goes into, how does that rubber boot come out & then is there a circlip behind it ????
Thanks Rob
1 - 20 of 28 Posts
[align=center]
[/align]
[align=center]Welcome:waving:robcath[/align]
Hallo robcath
And good luck with your Wing.
:waving:Greetings from N.Idaho and welcome to the Best Goldwing Forum on the internet. If used, this forum will supply you with great information and hours of simple entertainment.
Don't forget to post your question in the tech area.
[align=center][/align]
[align=center]
[/align]
[align=center]Howdy robcath.............:waving:[/align]
[align=center]One Hundred Thousand Welcomes........:claps:[/align]
[align=center]To The Worlds Greatest Goldwing Forum..............:claps:[/align]
Hey there! :waving: from Hamburg, NY
[align=center]THIS IS A GREAT PLACE TO BE![/align]
If you have Goldwing Technical Smarts - GIVE IT! :readit:
If you need help - ASK FOR IT! :?
If you know of an event coming up or a cool ride you went on - SHARE IT! :12red:
If you have a joke or funny story - TELL IT! :ROFL:[/align]
If you have prayers to give or need some - FOR HEAVEN'S SAKE, SAY IT! :praying:
If you have anything bad to say to or about anyone on this forum - STUFF IT! :lash:
[align=center]WELCOME TO THE FAMILY!!!
[/align]
Howdy and welcome to the forum! :waving:
welcome aboard
WELCOME:waving::waving::waving:
Warm welcome to you buddy
Welcome, WelcomeTo Steve Saunders Goldwing Forum.If you have any questions no matter how trivial they may seem this forum is the place to ask them. What I have noticed is that some of the people here were :15red:'sin their previous lives and can answer any question you have. Theforums that I get the most from are::
Goldwing Technical Forum
General Motorcycle Discussion Forum
These have the best info aboutGoldwing’s and are where you ask questions and can get help..
For Sale/Wanted ForumGood stuff for Sale or if you have old parts sitting around the garage you would like to get rid of....
:18red::15red::12red::11red:
And when all you need is a good laugh to start your day try the:: Fun Forum After that it’s up to you which of the others you will like the best all I can do is suggest.
Again Welcome to the Forum...
Oh and did I mention everyone here loves pictures.. Show us some of yours... Even if it’s not a Goldwing just a pretty view
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
Yes there are circlips. Once you start removing stuff you'll see it's simple.But you may be getting ahead of yourself.
Have you tried to bleedthe systemwith a vacuum bleeder? They really do make a big difference.
Also, inspect the slave cylinder for leaks or sticking.
See what happens when you post in the Introduction forum.:ROFL:
Look at your master cylinder, it goes uphill to the hose fitting, place the bike upright with bars to the right and pump the clutch lever.
If the problem is trapped air there it will be flushed back to the master cylinder and the lever pull should firm up.
Welcome :waving::waving::waving:
Yes another hearty welcome to the forum robcath
You will have to clean the master cylinder and the slave cyl too. After cleaning the master you will need to bench bleed it to remove air in the master, then bleed the system.
In the repair manual there are instructions to clean/rebuild. Might be some in the GW workshop section under menu and also in the reference and FAQs forum pages.
Goldwingdocs.com has a good selection of how to do's.
Rob,
Before you take it apart beware. Lots of people have trouble bleeding the clutch on those bikes. The problem is the master cylinder is not the highest point and air gets trapped by the banjo fitting. Try this. Put the bike on the center stand and even tip it ever so slightly to the right if you can do that safely. Next turn the handlebars all the way to the right. Now you have the master at it's highest point and it will bleed. That problem has driven myself and many others crazy before. Good luck.
1 - 20 of 28 Posts
