Hello,
I just purchased a non running “ran when parked 5 years ago” GL1200 interstate. I got the bike home and the engine seemed to be locked up. I pored some MMO in the cylinders while I pulled off the timing belt covers and once I got a bar on the crank bolt it would move freely back and forward half a turn but it seems to be hitting something hard pretty much 180 degrees apart.
Is there anything common that might cause this? I would like to not have to pull the engine down completely because the bores look good through a bore scope, the valves arnt sticking because I removed the timing belts and cause move them freely.
Anyone have any ideas?
