1 - 3 of 3 Posts
Hi guys, have just received some LED SMD bulbs to replace my rear/trunk lights in my '84 GL1200, and, as they have a sensor assembly to sense when there is a (standard) bulb out, I understand that the LED's will not work correctly...so I need to bypass this "sensor" (brake and tail light sensor, P9-24 Haynes)so that the led's will fully work. Where is this assembly?...I have removed the seat and it looks as tho the wiring goes under the faux tank to the "sensor"....does it?.. do you know??...
Many thanks.....
Many thanks jwhitmore44, your link led me to an image of where it is and will check out the yellow/white wire, should be able to work out the wiring from here, Cheers.
Peter.
1 - 3 of 3 Posts
