Can anyone help me? There is a 1984 Interstate Goldwing that when you are going down the road it will die. Just as if you turned the key off. But then it will not restart. Also, it does even try to turn the engine over. There is no pattern to this problem. It can happen back to back in one day. But then not happen for a couple weeks.
The key switch was changed out last year. Losing the gas cap did not help. Coils are not cracked. If you have it running in the garage and wiggle the wires, it does die. Put a salvage CDI on it last year. Couldn't find a new one.
Has anyone experienced this problem? Do you know if it could be the CDI? If so, how do you test it? Any help or suggestions would be appreciated.
Thank you,
Penny Hynson
goldwinghelp
Thank you,
Penny Hynson
goldwinghelp
