1 - 20 of 30 Posts
I'm considering purchasing a 1985 GL1200 Limited Edition (Gold/Brown). If this model is the one with fuel injection, are there any concerns with this purchase that I should be aware of?
I've heard a few bad things about the CFI system. Are they incidental or widespread?
Just bought one, yes it does have the fuel injection. I don't know a whole lot about it yet.......but I'm lovin' it so far:action:
Welcome to the forum!!!
Welcome to this Great Site!
Pull up a chair and join on in!
Ride Safe, Ray
:waving:
Guru
Welcome to the forum! the 1200 is a solid powerful bike. the biggest downfall on a 1200 is a failing stator. (the charging system).
Ask the owner if it has been repaired or replaced. To pull a stator, you must pull the engine. You can also buy a "Poor boy" kit which is an external alternator driven off the front of the engine. It looks pretty cool & supplies way more power than a regular Wing charging system.
I ride an 86 SEi, the same bike basically as the 85 your looking at. Runs like a watch, never gives me any problems. I do run seafoam through the gas tank a few time a season and haven't had any problems with the fuel system.
there supposed to be very fast but when you have a problem you should be schooled in fuel injection systems to get the bug
Welcome to a great forum bobsolorider. I'm a solo rider too. You have to think about how long your going to keep the bike. I'ver heard and been told by bike mechanics that the LTD is getting very hard to find parts for. Now I don't know if he meant just here in Canada or all of North America. And as hatchetman said about the stater problem, I would put in all LED lights in. That is what I did and got rid of my problem. If you do buy LEDs, make sure there made in the USA and not in China. Good Luck on your decision. :waving: :)
The above is reality - the stator replacement is verrrry costly! I personally would not buy it if the stator has NOT been replaced.
If the bike starts fast and runs good - try the seafoam treatment in the tank. It won't hurt.
Discussion Starter #10
Owner says he had the stator replaced a while back; part not so bad, labor to pull the engine was the catch.
Discussion Starter #11
Ok, what's the gag? What is seafoam? My wife's a decorator and says it's a nice color for green carpet.
:D Got to love it. Seafoam is a fuel system cleaner. Very good reputation.
I had the opportunity to drive a LTD and it was very smooth and powerful. My GL1200 A
is no slouch but the LTD was significantly better.
I understand that parts and pos. repairs could be a problem, but this forum can be be great asset with its great members and knowledge.
I had to replace my stator and will not do it again. Converted to the external alternator and am loving it. You can do it yourself if I can. Alot of help here on the forum. Do not pass up the bike because of the stator issue. I think you will love the bike IMHO. Randy
I love my LTD!!! Take advantage of the guru's on this forum, they are fantastic and have saved me time and $$$ on a few problems I was having. Running like a champ and loving it!
My GL12 doesn't have EFI but I have two other bikes with and love it.
Does the PO have the paperwork from the stator change? Are the stator wire connectors changed out or by pasted?
Hey Everyone -
My name is Jason Myers - just bought a suffering 85 LTD, with 180 000kms on it. Mechanically ok- and even though I have not ridden it yet - love it (kinda whacked I know) This is my first Goldwing, always wanted one. Been adventure biking and sport touring most of my life. Finally - a "real" seat!!
Look forward to learning - and hopefully contributing to the forums as I prep the wing for combat air patrols. I have a regulator to install (Stator good) - air leveling, cb radio, trip computer and audio are non existent work wise - but will troubleshoot one by one.
Im going to ask about abs plastic repair - im planning on using fiberglass resin, plastic patch and a few rivets as its the bottom of the left saddlebags. Appreciate any thoughts.
First post!! Sorry if there is already a post on the plastics repair - still learning :)
Jason
Welcome to the forum Jason,
Congradts on the purchase.
This is an old post so watch the dates. Best to start a new topic of your own rather than tagging on an old on, you are OK so far. Lots of good info in the old posts to glean, for sure.
1 - 20 of 30 Posts
