1985 GL1200 Clutch won't disengage
6306 Views 14 Replies 8 Participants Last post by  mreid2005
Hey all!
I'm having a problem with the hydraulicclutch on my 1985 GL1200 LTD after a stall and dump in my driveway.
To make a long story short, I dumped my LTD into the hedge bymy diveway last night after misjudging my approach to the driveway, which is a rather steep uphill drive. I was in 1st gear and moving at maybe 3 or 4 miles an hour, when the highway pegs snagged the bush, directed me into the bush, and subsequently ended up stalling out as the bike wedged in the bushes.
I did't have the strength to right the bike by myself, and left it in the bushes by the driveway overnight. This morning, a neigbor helped me get the bike upright and out of the bushes, but I was dismayed to find that the clutch would not disengage, and I could not shift the bike out of first gear. We managed to drag the bike up the dive, approximately 75 feet, using a rope and my pickup truck,to where the drive levels out, where I was finally able to get the transmission into neutral, and push the bike into my garage.
I had noticed some seepage around the master cylinder a few weeks back, and had purchased a rebuild kit, so this evening I rebuilt the master cylinder and bled the hydraulics. I'm getting a steady flow of fluid with no bubbles at the slave cylinder now, but still cannot get the clutch to disengage.
Does anyone know why this might be happenning? The bike was partially on it's left side for about 6 hours, and I have had stalls in the past, but never had a clutch failure til now.
Is it possible that something may have failed due to the bike laying over?
Could there still be air in the lines that is just not comming out during bleeding? Could theclutch or slave cylinder be bound up due to the bike laying on it's left side for a evening or the stall ?
Thanks in advance for any insight anyone might have.
1 - 15 of 15 Posts
Try cracking openthe banjo bolt on the master cylinder and bleeding it there. Every time mines gotten low on fluid and the clutch was not disengaging fully, that's been the ticket!!
how does the lever feel? it try using some kind of vacum pump, you can make one out of a big syringe or buy a cheap one.
i would try bleeding my clutch at the master cylinder where the big bolt is.
since it fell on its side it may have an air bubble at the master
Thanks, roscoepc!
I did bleed the air from that area when I first reassembled the Master Cylinder, but noticed some air bubbles in the reservoir after it sat for a while. I'll try bleeding at the union again, once I get to the auto parts store and get some more brake fluid (I used up the small bottle I had).
Get some help and gently lay it on the right side. You can even lean it on some bricks or scrap lumber, at the engine guard. Just lean it like it had a right side side stand. Then squeeze the clutch lever, hold for a few seconds and release. Do this several times. Tilting the bike to the right will let the air bubble to escape past the banjo bolt. When leaning to the left, the air gets trapped at the banjo bolt. Then have your helper help stand the bike back up.
Hardly any resistance. I do get a delayed steady squirt of fluid at the bleeder valve with each pump of the lever. I think I will try the vacuum pump idea if they have any at the auto parts store. I'm convinced there is still a lot of air in the lines, and that I probably need to run a lot more fluid through the system to get it all out.
Thanks for the suggestion, johnmac!
I'll try that if further conventional bleeding doesn't help. I may have trouble getting a second hand to help lay the bike over, but I have a floor jack that might just do the trick.
When you try to get to the bleeder on the back of the engine you will see why other "tricks" are offered! :cool:
Just a follow up. I tried something similar...by turning the handle bars hard to the right, I leveled out the "pipe" that leads to the junction, and got quite a few bubbles out of the pin-hole at the front of the reservoir. After refilling and capping the reservoir, I now have full resistance and travel, and the clutch works great!
Thanks to all for your suggestions,
Glad to Hear you found an easy fix!
You guys didn't know it but I had the same problem. Clutch would not disengage. After spending an hour trying to find the bleed valve I GAVE UP AND CAME INSIDE TO PLUG IN MY PROBLEM IN MY COMPUTER. YOU GUYS ANSWERED MY PROBLEM INSTANTLY. I WENT BACK OUTSIDE AND BLED THE MASTER CYCLINDER THROUGH THE BIG BOLT ON THE END OF THE MASTER CYCLINDER. WOW I HAD CLUTCH DISENGAGEMENT AGAIN. THANKS A MILLION.
That's why we love this forum.
Welcome to the Site and I'm glad you not only found a solution but made a post saying you did!!! Hang around and don't be a stranger!!!!:coollep::coollep:
Just to confirm -
this worked for me also.
I hadn't ridden in almost a year if not more, took a two block spin, trying to figure out why she's stuttering.
parked it, worked on spark plugs the next day, went to pull in clutch, and it was softer then a baby's behind.
Turning the handlebar way to the right.
mine may be a little high compared to others, but basically just shy of touching the windshield, while on main stand.
pump a bunch. bleed.
Pump a ton more she'll burp.
bleed.
KEEP doing it. it will pay off! :) heh
1 - 15 of 15 Posts
