I'll chime in here. First, do you have the manuals needed for your bike. These are the OEM service manual, Electrical troubleshooting manual, and the supplement - this is the real important one. Without it you are going to ask a lot of questions and get a lot of opinion.
Loading up the spark plugs. Have you adjusted the idle on your bike at any time and if so, which screw did you use? There are two screws that can be used, but only one is specifically for the idle - located in the centre rear of the air chamber. The other is to balance the right left cylinder banks located behind the right CFI cover and is not to be used to adjust engine idle.
If you use the screw for the cylinder bank balance adjustment to adjust the engine idle, you will affect the fuel to the cylinders. This screw should only be adjusted when you have vacuum gauges connected to each cylinder bank. The engine idle will have to be adjusted as well if you change the engine cylinder bank adjustment.
The PB sensors should not affect your issue.
There are aftermarket injectors that can be used but must be low impedence injectors - 3.0 ohm or less. Injectors for an early model Civic/Prelude - 1985 will do.
ECU will affect fuel to the cyclinders, but primarily because of the TPS setting. Calibration too high, excess fuel used. Calibration too low, lean condition.
Good luck.
Are there any error codes on the ECU? The ECU are very robust and don't fail too often.
Thanks very much for the reply.
1. I do not have any manuals other than what is available online.
2. Have not adjusted the idle, but I did read to see which screw was for the idle and which one was for the carb sync. Thanks for that info though.
3. Exactly what is a PB sensor and what are the vacuum hoses for that go to it?
3. a. Are you saying that the injectors will not over fuel the engine if the vacuum hose to the PB sensor/sensors, is leaking?
4. I did read on either this site or another site about which automotive injectors will work, and thanks for that info.
5. It is only over fueling the 2 right cylinders. Is the ECU split inside so that if one part of it goes bad it can over fuel the cylinders on one side or the other?
6. I had no idea there was a way to check for error codes and have no idea how to do that.
It is flooding both right cylinders the exact amount, which made me think that the problem was in something that controlled both right side fuel injectors independently from the left ones, instead of both fuel injectors failing at the same time.
I have been a vintage auto and motorcycle mechanic for over 40 years, and I also a high performance engine builder and tuner, and have jetted over 2,000 carburetors, but I know very little about fuel injection and computers or electronic control modules of any type.
