I am having charging problem with my cycle. I have replaced the plug both sides with a kit from the stator. I have also replaced the rectifier/regulator assy. What I am trying to determine is the dynamic voltage that should be across the three stator pairs minimum. At 3000 rpm I have 70 vac currently. I have a couple things I can’t find:
1. There are 2 ground lugs shown on the schematic (eyelets), where are they physical located? I have a 84 mv. drop from frame to regulator ground.
2. Where can I find the charge troubleshooting section for the Ltd Electrical troubleshooting manual?
hello,
just wondering if you have the correct rectifier....the ltd one is different from the interstate and aspencade, it needs to be able cope with the higher output from the stator.
cheers,
You might pick the manual on the web.
Look forward of the cooling resevoir, and down on the frame
Ben
