Double check your faults. I have the Honda ETM for the 86 SEi which is likely the same for the LTD. The faults you listed indicate a faulty Engine Speed or NS sensor which is located behind the timing cover. The wiring comes out of the top of the timing cover slightly to right side (as sitting on bike).Yes the ECU under the trunk has the W light on solid and the #3 and #0 lights are flashing. According to Honda diagnostics it is the crankshaft angle sensor. I checked it with ohm meter and it is open, so I'm badly in need of one.
Be careful not confuse component names. The Ns sensor is the crank position sensor. It references engine speed. The GL and GR sensors are "cam" position sensors. I believe nagger007 has it correct. Symantics(?) in fuel injection can be confusing at times.nagger007 wrote:Double check your faults. I have the Honda ETM for the 86 SEi which is likely the same for the LTD. The faults you listed indicate a faulty Engine Speed or NS sensor which is located behind the timing cover. The wiring comes out of the top of the timing cover slightly to right side (as sitting on bike).Yes the ECU under the trunk has the W light on solid and the #3 and #0 lights are flashing. According to Honda diagnostics it is the crankshaft angle sensor. I checked it with ohm meter and it is open, so I'm badly in need of one.
Crankshaft angle sensors GL and GR are located on r/h rear cylinder head at end of camshaft under 4 bolt cover.
Semantics yes indeed. However,I am not confusing them GL. The ETM specifically -in the self diagnostic section - lists that code(the one in his 1st post)asfaultyEngine Speed (NS) sensorverbatim which-on the fuelies issimilarto the pulse generators only there is one not two under the timing cover.wingsam41 wrote:Be careful not confuse component names. The Ns sensor is the crank position sensor. It references engine speed. The GL and GR sensors are "cam" position sensors. I believe nagger007 has it correct. Symantics(?) in fuel injection can be confusing at times.nagger007 wrote:Double check your faults. I have the Honda ETM for the 86 SEi which is likely the same for the LTD. The faults you listed indicate a faulty Engine Speed or NS sensor which is located behind the timing cover. The wiring comes out of the top of the timing cover slightly to right side (as sitting on bike).Yes the ECU under the trunk has the W light on solid and the #3 and #0 lights are flashing. According to Honda diagnostics it is the crankshaft angle sensor. I checked it with ohm meter and it is open, so I'm badly in need of one.
