I just purchased a 1985 Limited. Was not charging when I bought it. I tested the stator and it tested good. Bought a new voltage regulator and charging system shows 14.3 volts at idle now. Now the problem, the motor feels like it is running on two cylinders until it hits 2000 rpm. This is my first fuel injected 'wing, so I am learning as I go. I put Seafoam in the tank to try to clean out the fuel system, just in case. When I let off the throttle while slowing down, it pops out the exhaust pipes. On my days off this weekend, I am going to do a spark test to make sure it is firing on all 4 cylinders. Any other ideas?
suks2bu37
suks2bu37
