bailbob wrote:
Well I took off the cam cover and all the rocker arms are working nothing loose or damaged and each valve seems to be intack, I do not know if the slides on the carbs are working except they seemed fine on the bench each moved freely, but still no gas. I sprayed the starting fluid into the carbs and nothing, took the spark plugs out and sprayed starting fluid in there and nothing. I can hold the spark plug against the motor and I have spark but then it stops. I then try again and the same thing happens. I am unable to put my hand over the back of the carbs as the air filter housing is still intact. STUMPED!
If you don't have a steady spark......you need to go back and troubleshoot that.
Verify you have the correct plugs, they are fresh, the boots/wires aren't shorting.....etc.
When you hold the plug against the engine and crank it........it should have a nice bright steady spark, you should see it and hear it in time with the engine. If it's intermittant.....you need to solve that.
Also.....you need to get the airbox completely out of the way while you're trouble shooting. You need to be able to verify that the choke is functioning, the sliders are moving, the carbs are sucking (have vacumn) etc. You also need to be able to get gas/starter fluid straight into the carbs.
I guaranteedangtee you......if you've got spark, your compression numbers are right, and you spray gas straight into the back of the carb IT WILL FIRE.
You intermittent spark leads me to believe that you still have not sorted out the ignition side.
