I tried to post this yesterday.
I took a short ride (very short). The bike made a few brrap braap noises from below the seat area. I thought it was the centerstand dragging. Then it made a continous grinding noise and lost drive power.
The engine still purrs fine and all is quiet in neutral. I gear there is a grinding noise that increases in tempo when shifting from 1 thru OD.
The bike can be easily pushed while in any gear with the clutch fully engaged(emitting the grinding noise of course).
The bike has about 38,000 miles on it. I had the rear tire changed this summer. I had to return the bike to the shop because the rear brakes didn't work. They indicated a sheared caliper pin. I suspect they are the root cause of my problems.
What are the likely problems and cost of DIY repair???
