I started my bike and let it run for a few minutes. When I shifted it into gear it quit. Now the fuel pump and air pump aren't working and it won't start. :(I've checked the fuses and can't find a problem..Any ideas?
Not much to go on there. does the engine crank over? Does anything come on, lights etc? Does the neutral light come on ok? When you put it in gear and the engine quit was the sidestand down? Have you raised the sidestand and or pulled in the clutch lever and tried it??
Thanks for your reply.I have tried to start it with stand down and up, also with clutchpulled in. Starter turns over butfuel pump will not pump. All lights are working including dash components. Just found out there is no power to fuel pumprelay which also means no power to fuel pump. Pump does run on alternate power source. Can't get the air pump to work, but I don't know if it has to be running to operate. Any suggestionsare welcomed.
Check for power going to the fuse #6 I think it is. the same fuse powers air pump and also fuel pump relay
1200's don't have cut off switches on the side stand
Checked the relays with a meter and it looks good. I think we maybe narrowing it down between the fuse and the relay socket. I will know tomorrow and let you know what I find out. Thanks for your reply.
