I have been rebuilding my 86 GL1200A. I had the carbs rebuilt at shop and was started and running wuth an IV to the carbs. I had a rust problem with tank and since have cleaned all out and ran gas from tank until all clear. Problem is that when I hook to gas line and try to start the gas doesn't flow. Should the fuel pump come on when key is on? If I run test leads directly from the battery to the fuel pump shouldn't it come on? When I did it nothing happened. I figured I would do a direct test to the pump before going to the relay.
