1986 GL1200 Aspencade SE-i
839 Views 4 Replies 5 Participants Last post by  maineman66
What are the chances I can find a fuel pump for this fuel injected engine?
I did the same when I had an SEi. It was a fairly easy fix, just make sure there is a filter on the inlet to the pump, or it won't pump for long. Use the pump mentioned - a lower-price won't be the high pressure FI type you need.
Sent from my LePanII using Tapatalk 2
yep...a little over $100. The fittings & electric are the same but a little smaller in diameter but theres a rubber spacer included. Changed mine last fall. When you take your old one off check for a small filter cone and use it if theres not one with the new pump,,, I don't remember if mine came with one or not
Fuel pump
Hi there I think if you call this # they'll have what you need.712-722-1925.Good luck I have the same bike as you do and it's in the shop right now getting a TPS put on.I was on the computer 13.5 hours yesterday trying to find part but this guy really seemed honest and fair!!
