I just took a 2,200 mile trip on my GL1200 and on the way back home it started running very poorly at low RPM's. It got progressively worse and worse over the course of 1 day until the bike plain wouldn't idle by itself or take off from a stop without lots of throttle. I later realized that the issue was only occurring under ~3,000 RPM; anything above that RPM (highway speeds) the bike ran perfectly fine. So, since the ride home was mostly interstate I "limped" it back home.
Using a spark tester, I found out the back 2 cylinders did not have spark at idle (and I assume up to 3,000 RPM as well), while the front 2 cylinders were good. So, to wrap this all up - any idea what would cause it to have weak/no spark on the back 2 cylinders at anything below ~3,000 RPM? I have checked the primary and secondary coil resistances and everything checks out per the manual. Before I do anything else I figured I'd consult the community on here since there may be something obvious I'm missing.
Thanks in advance!
Most likely the pulse generator but never trust an ohm test on an ignition coil.
02 GL1800 w/Auto Pilot
good news, glad it running for you again.
