1 - 14 of 14 Posts
Hi Everybody,
I have started a project on a 1986 GL1200A that was wrecked in the front. The front forks were bent in and I managed to get them off after a lot of persuasion but now and having a lot of trouble getting the other ones I bought back in, is there a trick to doing this? Are they supposed to be diffilcult to get in? I have got them past the first set of clamps but the top ones are where I am having problems. Any help will greatly appreciated.
I'd guess you have a bent triple clamp.
Oh, and welcome to the forum.
+1
Replace the triple tree upper and lower and new bearings.
Is the paint chipped, cracked at the frame neck?
What was the crash speed?
Junior Grue
Loosen the nut atop the upper bridge and see if the upper and lower will line up, if not something is bent.
I am thinking the lower ones are the bent ones, because once I got through them they wouldnt quite line up with the uppers, I did however manage to get them started in the uppers but cant get them to go all the way.
When you pull the triple tree you will find it is bent. Replace both top and bottom from a know uncrashed bike.
The steering head bearings are undoubtedly damaged and will need to be replaced as well. Even a large square edged pothole can dent the outer and inner races and cause weird and scary handling.
I would say that it is quite possible the frame alignment could be compromised as well causing the bike to pull to one side or worse. I've seen a 1200 frame damaged by a fairly innocuous lay down to the point where it never did track true afterwards, but, on the other hand I know of one that took a fairly severe impact and seemed fine afterwards. The only way to check without sophisticated equipment is the old tried and true method with two straight edges on either side of the wheels.
Hope it all works out for you. Sometimes a bargain turns out to be the opposite.
Discussion Starter · #11 ·
Ok Thanks Yes I agree that a bargain isnt always as it seems. One more thing do you know if a Triple tree set up from an 86 Interstate is the same as the Aspencade.
1 - 14 of 14 Posts
