1 - 15 of 15 Posts
Hello everyone.I am working on a friends 1986 gl1200 interstate.I'm having trouble finding the pulse generaters.The manual shows them to the rear in 1984 and in the front after that.I don't see wires going into the timing cover nor do I see wires near the driveshaft.I've unplugged the cdi module and tested the pgs and yellow and yellow/white are open.Am I missing something?
Hallo jetmate570
And good luck with the Wing.
Hello and Welcome . I do not have experience with a 1200 . On the 1100 the Pulse Generator is located at the rear of the engine in the center ,between the driveshaft and the stator housing . The 1100 PG has the wires exit out of the bottom of the cover plate ,and run the wires up the left side of the frame to a connector just in front of the battery . I would expect the 84 to be similar .
AS you said they moved to the front of the engine after that point .
If the later 1200s are similar to the 1500 which followed it , the PG is located on the front of the engine . They are operated by the trigger wheel mounted on the crankshaft . On the 1500 the wires exit from under the timing cover at the top near the center .
IF you can post your question in the Technical Forum section ,you will have more exposure and the 1200 GURU will soon be able to offer better help .
Gregarious Greeter
Welcome:waving:jetmate570
Most new members don't realize that the Steve Saunders Goldwing Forum is much like an extended family and as such we like to get together on various occassions to renew old friendships and make new ones. For example, each year we put together a huge celebration called the North American Steve Saunders International Rally (NASSIR). Unfortunately you've just missed NASSIR 6 in Simcoe, Ontario however there is plenty of time to plan on attending NASSIR 7 which is being held in Fontana Dam, NC on July 8-10, 2014. If you want additional information please follow this lnk and it well take you to a dedicated information page for the event! Welcome aboard!!!
http://www.goldwingfacts.com/forums/13-nassir-meet-n-greet-forum/444833-nassir-7-information.html
Welcome, Welcome To Steve Saunders Goldwing Forum so withany Maintenance you do.If you have any questions no matter how trivial they may seem this forum is the place to ask them. What I have noticed is that some of the people here were 'Goldwings in their previous lives and can answer any question you have. The forums that I get the most from are::
Goldwing Technical Forum
General Motorcycle Discussion Forum
These have the best info about your bike and are where you ask questions and get help..
For Sale/Wanted Forum Good stuff for Sale....
And when you just need a good laugh:: Fun Forum Again Welcome to the Forum...
And A Big Welcome From Clermont, Indiana.....
Discussion Starter · #8 ·
WOW...Thanks for the big welcome and suggestions.I enjoy helping friends out and many of you made that easier for me.Thanks again!!I'll post when I get the issue solved..almost there.
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
1 - 15 of 15 Posts
