1 - 3 of 3 Posts
Hello all,
Well as I dust off the bike for a test run this spring I decided to fix a problem I have. The odometer is not working. The speedometer works fine but I am not racking up any miles on the odometer. Does the odometer get the millage info from the speed sensor on the front wheel or a different place?
Thanks for any help as I try and figure this one out!
1985 GL1200 Limited Edition
You are talking about the mechanical odometer on the lower left of the dash correct? If the 2 digital trip odometer's are working along with the speedometer, I'd say as a guess that there is something broke inside the instrument cluster. Another instrument cluster might be in order.
Be of good cheer though! Someone alot smarter than me should be along shortly to help out and it might be a simple fix!!
Hi,
Yes the mechanical one is the one that is not working. The others work fine.
1 - 3 of 3 Posts
