1977 gl1000, 1987gl1200
I am rebuilding the carburetors on a 1987 1200 Interstate. I'm confused on the jet size. All the rebuild kits come with a .35 small jet and a 102 for the large. The ones coming out are 40 and 105. Being told that jet sizes differ in different elevations. I live in northeast US. Is it that critical. Is it going to affect performance. Any info would be appreciated
Use the original jets. They don't wear out and you can't depend on the aftermarket jets being the size they are marked.
The carbs were bad with gas residue. The large jets clean ok but on the small ones, can't get a piece of wire thru. Is this normal as all 4 seem to be blocked at same spot
The hole in the slow jet is very small. I use a single wire pulled from a wire brush.
Got them clear. Just took patience, a smaller wire, and a little help from this great forum. Going to use original jets as you suggested. I was very skeptical about the aftermarket ones being different size. Thank you.
