Years ago I was given a swing arm, brake caliper with mount, final drive, axle,and wheel with rotor in payment for restoring a 77 CB750A. At the time I would rather have had cash, but the person I got these parts from had a trike kit put on his 93 SE and did not have a lot of extra cash. He bought the 93 and rode it for less than 100 miles before he trailered it to the place that did the swap. The tire still has the nubs in the middle of the tread (with all the talk about all the issues with the new-new tires on the market itstempting to use this tire).
I will be putting on a new rear tire and doing the full inspection soon, and I am reasonably sure that the final drive has never been off my bike. If I find wear in any of the splines I would like to know what parts will bolt right on and what won't. I have the above mentioned partsIF I need to use them. Also, I will be looking at the swing arm for rust as they are prone to fall apart, but this bike saw little to no rain and NO salty roads ever (I am the second owner and first met the first when the bike was less than 2 years old) and its first 10 years was stored in a heated garage.
My bike has a vibration onheavy decel at speeds above45 that feels like its coming from the rear wheel. It has always had this but it has gotten a little worse over time. There are no clunks or any other odd issues. Depending on what I find I might just buy and replace the isolators and bearings, but any shaft or spline damage/wear I will swap out what I need, even if I need to buy extra stuff to do it (as long as its cheaper).
From the searching I have done, I have found that if I want to use the 93 wheel on my 88 I would need to change the swing arm and brake assy. including the 93 rotor. Would anyone call this an 'up-grade'?
More searching indicated that the final drive hub is fully interchangeable all years (I assume all the same gear ratios too. I would like a taller one), but I also found that the 88 driveshaft is different than any other year. I also know the number of pins in the 88 driven flange is different than the 93, but I have read that both flanges fit the same way into the hub.
The main answers I am looking for:
Will the 93 hub fit my 88 without the need to change anything else?
Is the later driveshaft needed for the swap and/or is it even an upgrade?
Is there a place other than a dealer to get the rubber wheel isolators for an 88?
I know much more about the 'older' wings, but its about time I get to know more about the one I ride now. I did the carb.s this spring icluding the REAL off-idle fix, plus a fork brace and fell in love with this bike like never before.
Thanks in advace,
Bill
Thanks in advace,
Bill
