1 - 9 of 9 Posts
Piaggio MP3, was 02 GL1800
What model bike? Please always include the bike's model in the Title description line.
We don't have a clue as to what schematic to diagnose with.
If you pull off the left cover just behind your left leg is the fuse/relay panel. Check to see which relay is engaging and go from there. No relays should be active with the key in the off position. Might be wiring or the relay itself
Okay....If I disconnect the RED three wire connector ( second inward from the right saddlebag), the relay quits clicking. Brown white/brown yellow/green
Ah hah !!! Rear suspension wiring.
Now...Since I have a Richland trike kit installed and have the ride set to 0 psi....would it hurt anything to just leave this disconnected?
I would think that the OEM suspension wiring harness has been compromised and you finding out where is not worth the hassle of looking for it.
Leave it disconnected and protect the connectors so they cannot get shorted to anything.
1 - 9 of 9 Posts
