1 - 2 of 2 Posts
My 88 GL 1500 leaks a little bit of oil right under the motor. Because of all the cover I can't tell exactly where it is coming from. It may be coming from the gear shift seal but not sure. When you run the motor you can smell oil getting hot and a little steam or smoke comes up aroungd the handle bars. Not much and not all the time just every so often. From what I've read if it is the shift seal it can be a fairly big job, having to take lose motor mount???
1 - 2 of 2 Posts
