Morning all, quick question. Doing a carb sync on a 88, 1500 do I only hook the gauges to the vacuum ports on the intakes? I only found two of them. I dont have to get down to the carbs themselves i hope. Then i go through the groumet hole to adjust them? If anyone could shed some light on this I would very much appreciate it. Thanks and God Bless
You are sorted JB could not of explained it better myself,
only trouble you may have is finding the adjuster screw, when gaining access from the grommet, I take the Right hand fan out to do mine, saves all the bad language when the screw driver slips off the adjuster screw.
Nick
Welsh Winger
So i can only adjust the right side, correct? The left side is the non adjustable one, is this right.
Yes Jb thats it, only the right carb has an adjuster, thats the right carb while sat on the bike.
Links to instructions and pictures, and a video:
GL1500 Carburettor Balancing
Nick Welsh Winger
Thanks a bunch Welsh Winger. Now I just need to get or make a cheap setup and Im good. Thanks again
