Hi I am new to the goldwing bike, I just bought an 88 GL 1500 goldwing and have it in my garage and after it sat for a few days I noticed a few drops below the rear tire. Upon further inspection I see the bottom of where the shaft meets the rear tire (the round housing). It is not alot of fluid but was wondering what could cause that. I checked the fluid level and it is at the bottom of the hole that is there to check. And there are no noises or grinding just wondering if there is a seal in there that maybe leaking. The housing does not appear to be cracked. I just don't want to make this problem worse or cause a safety issue. Thanks in advance for your time and replies.
