1 - 20 of 22 Posts
Okay my fellow brothers...I need some help. My wing broke down 5 days ago..lost power and died. I tried to get it restarted but would just get a rumble here and there. Luckily it broke down in my work parking lot. Took it to the shop and they had it for 3 days. They said it was possible that the loose positive cable could have been the culprit. I put that battery in less than a year ago and i know i would not have left a cable loose. Apparently they could not reproduce the problem. Charging and battery and fuel pump were all checked and working in good order. Ran Beautiful home from shop and a couple of days later i took it for a 45 mile cruise and it ran flawless. The next morning today, I took it out of the garage, started it without choke and it started right away like it always does, then tried to engage the choke to run the rpms to 1500 or so and it would kill the bike. I turned choke back off and restarted the bike and ran the rpms up by throttle for a few seconds,,,it stayed running for about a minute and a half and then died. I restarted and took off. I could tell bike was not running smooth like it should..got a mile down the road and it started to bog going down hill and it died. I had to keep restarting to limp it back home. Bike smelled hot or if something was burning when i put it back in the garage. If anyone has some insight on this issue i would greatly appreciate it. Just paid almost 300.00 for them to look at it and change a few fluids...very frustrated :praying:
Discussion Starter · #2 ·
bike had only 21,000 miles
It aint rocket science
You have a fuel delivery issue, pump, filter or auto fuel valve.
they said the fuel pump was checked...filter looked okay..and the auto fuel valve? is this the same as the petcock? if so i rebuilt this last year with the kit..im definitley buying a new filter and installing
How and why would the shop check the fuel pump if no problem was found, it was running good while they had it. If it was running good they could easily say fuel pump OK along with everything else. They could not duplicate your problem. Was there an extra charge for testing fuel pump and is it written on repair order.
When you rebuilt your fuel valve what procedure did you use to test your work?
...and the auto fuel valve? is this the same as the petcock? if so i rebuilt this last year with the kit...
Yes same thing... Try By-passing it temporarily.
The re-build kits seem to often produce bad results.
Also, what are the symptoms when it dies? eg Still slow or sudden shut off of the engine? Still have all electrical lights on dash? etc
slow shut off like its loosing power.and i have all lights on.
Next time it happens take the fuel cap off maybe the tank isn't venting also check the vent tube on the cap.
Discussion Starter · #10 ·
sorry it has been a while getting back...they charged me a general amount for labour..it says they checked the fuel pump,,fuel filter..carberators. as far as the auto fuel valve, I had put it in my self and it broke down on me. I took it to the shop and he said i had the rubber piece upside down..he put it in the right way and it worked fine since.
Discussion Starter · #11 ·
well it did it again this morning...wanted to ride to work this morning because it has been running fine since i had taken it on several short rides of 40 or 45 miles or so with no issues. started up without even choking...took it out of the garage and within 5 to 8 seconds of putting it on the kickstand it started sputtering and i remembered that you had said to take the gas cap off to see if it made any difference...it did not. I started choking to get it running good enough to park it back in the garage. does the wing have a sensor if the bike is leaned to much? my driveway has quite a grade
Discussion Starter · #12 ·
Alex...how do you temporarily bypass the auto fuel valve?
Discussion Starter · #16 ·
followed the diagram of bypassing valve...started up and ran good...throttle response was good..but is it supposed to kick alot of smoke and rich fuel when this is done?
Discussion Starter · #17 ·
alex..is it normal for the bike to run rich and kick alot of smoke out when bypassing valve? throttle response was good..didnt act like it was missing like 5 minutes prior
Something severely wrong is going on in your ride.
Either the floats or float valves picked this instance to screw up or a previous owner put a high pressure pump in with auto fuel valve problems allowing it to run but with problems.:?
Now would be a good time to test fuel pressure and volume as a start.
The low pressure GW pump should just dribble the fuel out no more than an inch or so IIRC. If it shoots like a fire hose. NG.
1 - 20 of 22 Posts
