i bought this goldwing with being told it was the carbs were dirty...
well with further investigation ..i found out that the bike cranks over good
but has no spark to any of the cylinders...so i checked the kill switch..and
have power going threw it..on run...and then went to the check the fuses
and relays..fuses are good...and relays are good swapped them ..around...
still nothing...then went to the kick stand switch and by passed it..
and still nothing..so went to the tilt switch..and looks good..by passed it and
it still wont start....
then i went the black white wire and have my proper voltage...and power
to the kill switch and back to the computer...and also tried running direct batter
voltage to the ecm .and still nothing...no spark
then went and changed out battery ..just to rule that out...and still nothing
went to the ohm out the computer and seems ok...
so went to the pick up coils and one ohm out at 480 ohms...the second one
came in at 480 ohm and keeps climbing up on ohm..we got to 850 ohms
so i am assuming that it is shorted ....
any one else have some things i can try ...to look at??? you can send me a message here or
sent me a message on face book..under alan jones from farmington mn
or give me a call or text to 612 296 3940
