Hi, just out with the wife and suddenly all power is lost as if the kill switch was made. Turned it off, waited and it restarted and ran for about 1 minute then died again. This happened a couple of times and then she never started again. Battery's good. Turns over but does not fire. No spark from the plug so started checking ignition system. Fuel is present as I can smell it when I turn it over. Checked the primary and secondary resistance on ignition coils. Cylinders 5 & 6 show open circuit on secondary. Other two coils check out. What confuses me is if the other coils are good why won't it fire up on 4 cylinders?
comments appreciated
cheers
cheers
