My friend put the carbs back on today. They were cleaned at the dealer and re jetted with size 60 low speed jets. New plugs were also put in. He had the bike almost together by the time I got back from work. He test drove it and it was fine. I rode about 40 miles with my wife andno problems. I think we found the cure. I will report back after I get some more miles on her. WE WOULD HAVE PUT IN SIZE 55 LOW SPEED JETS BUT THE PREVIOUS OWNER HAD PUT ON A K&M AIR FILTER AND THE MECHANIC SAID 60 WAS WHAT I NEEDED.Any way so far all is good. I am blessed to have good friends that will help you when needed.
Carbs were not ready at the dealer today, but I will have them on wednesday. Machanic said that carbs looked clean but Ihad them cleaned and looked at anyway as the low speed jets were pluged when we removed them. He also said I had size 50 low speed jets in the carbs he thought that 55jets should have been changed with a carb modification back when the bike was new. I thought thatI read that the modification was fixed before the 1989's went into production. But I do not know for sure.
We will check again for vacum leaks using either starting fluid or carb cleaner before putting plastic on and after changing plugs.
Right bank middle plug was the nasty one but all plugs were some whatoily and sooty on the last two threads and part way up the electrode. Center electrode sticking out the porcelean was a nice light chocolate brown.I am suresome of these plugs were foulde enough to cause a miss. I had been running the bike previously with a little choke to keep itrunning. This might have conrtibuted the the bad plugs. If it still runs poorley after the bike is checked for vacum leaks I will changelow speed jets on the carb to size 55 like the macanic said.
Right now I am guessing that partially fouled plugs and cloged low speed jets caused the poor idle the flat spot in the throtlefrom 800 rpm to about 1700rpm with no response in between and some and some rolling rpms at low speeds.
At least I hope that I have found the cure.
two people about 1 .5 hours to get the carbs out and apart but my buddy had all the tools including a lift and all the knowledge.
What does the middle right bank funky plug mean?
jimqtip[/i]
Current time is 09:03 pm
pulled the carbs off today with the help of my friend.
We found no vacum hoses that looked bad. We did find that the slow speed jets on the carbs looked blocked.
I will take the carbs to the shop to be cleaned and put in new plugs.
The old plugs looked slightly fouled, some worse than others.
Am I on the right track?
Thanks,
JIM
just purchased a 1989 gl1500 with only 27k.The problem is the bike will not hold a smooth idle untill completely warm and then has a bad flat spot on acceleration. flat form 800rpm to about1700rpm and will not hold anyconstant rpmin between. Atpakring lot speeds the engine rpm's roll. Giving it choke will help but not cure. I suspect vacum hoses and possible slow speed jets. Am I on the right track? The 1988 had a parking lot slow speed manuvering upgrade done by honda to take care of a flat spot upon acceleration.Did the 1989 need the same upgrade or was this fixed before they went to production that year.
jimqtip[/i]
Thanks,
JIM
