Think that was US only.It may be the old bank angle sensor. Honda did a recall on that quite a while ago and were replacing them as a warranty item. IIRC, there was no time limit on having the recall done. You should be able to take the VIN to a local dealer and they can tell you if the recall was done and if not, they are still supposed to do it as a warranty item.
Here's a link to the Service Bulletin: http://www.goldwingfacts.com/1500%20Service%20Bulletins/1500SB6.pdf
pwhoever wrote:Not in the UK it seems. I just got onto Honda UK 0845 200 8000 to see if my1991 GL1500SE has been 'done' (as its really alarming to overtake with no engine) but they told me their database only goes back bikes that are ten years old or less! So it doesn't actually exist.... ah well.I did discuss it with an ex-dealership today too and they said, oh yes, but it only affected european models in very hot weather.... they gave me the phone number.So now Im not sure. The dealer (that was till recently) said engine cutting out is probably NOT the bank sensor but the ignition switch (which has, I'll admit, seen better days...I can take the key out in ANY position... but surely if the ignition was intermittent then it would have re-started when I clutched and hit the starter (it didnt turn over at all) but if the igition had gone off and stayed off then the oil light would have been off too... and it wasnt. Cycling the igition off and on and I was able to start straight away. So that sounds like the bank sensor right? er?Think that was US only.It may be the old bank angle sensor. Honda did a recall on that quite a while ago and were replacing them as a warranty item. IIRC, there was no time limit on having the recall done. You should be able to take the VIN to a local dealer and they can tell you if the recall was done and if not, they are still supposed to do it as a warranty item.
> +1G goes to R/W
W stays open. At least that is what it looks like would work to me from the schematic.
