I just replaced my 1990 in tank fuel pump using the Berry PDF process.I'm a little concerned
about the air hose being excluded in the rebuild?
I have about a 1/2 tank of gas and have the hose before the fuel filter off to see if there is
a gas flow when cranking. I can hear the new pump pumping when cranking but no fuel.
I have tried to prime the pump by siphoning gas through the pump using a hand unit. I get
fuel through the pump and into a container. I tried cranking and siphoning but still no
fuel pumping out with just cranking. I'm stuck on what to do next. I could add more fuel
to the tank and try again. Need help!
