Coming home from a 500+ mile trip yesterday, going about 55mph on the highway, a loud 'whistling' noise came from up front on the bike. First thought was my front tire sprung a leak. I radio'd the trouble to the others we were riding with and immediately pulled into a parking lot. The noise was loud enough that the others heard it too. Tire was fine.
I shut the engine off, the noise stopped. Started it back up, noise returned, pitch of the noise follows the throttle.Done this several times.Not seeing any steam, fluid, or smelling anything abnormal, determined the noise to be a vacuum leak. After looking everything thing over very carefully, I noticed the idle on the bike near 2k rpm's in neutral, but in 1st gear it dropped to 1200+ rpm's.
Managed to finish the last 90 miles safely, but every time we came to a stop, or I had tol pull the clutch, the engine would run upto 2k rpm's. While downshifting to 4th and 3rd gear, engine stayed at 2rpm's, 2nd gear it would drop to 1500 rpm's, and in 1st gear about 1100 rpm's.
Any ideas what the problem is, and if so, where do I go in at on the bike to find it. What all needs to be taken off to get to the problems???
