#1, probably a tire problem you didn't notice with weak forks.
#2, Changing the cam timing affects the vacuum so the carbs need to be readjusted to compensate.
#3, There is either a bad connection at the plug on start relay A next to the battery or a bad ground.
#4, Probably does or did have a sticking piston or caliper slide pin. I don't think an hour labor to flush the brake fluid is unreasonable.
