I have a 93 1500 SE that is blowing fuses. The same 2 fuses. they control the horn, radio, turn signals, brake lights, and cruise control from setting. Cruise will still turn on, just not engage. Any suggestions on where to start looking?
They will light short or not unless everything on the circuit is disconnected.I would jumper a light bulb into one of the two fuses, or both at the same time ( 2 separate bulbs ).
When the short is present, the bulbs will light up.
that will allow you to move the wiring harness around while you hunt for the problem.
when you find the short, the bulbs will go out... allow you to verify the source, you can move the wire/relays around until they stay unlit all the time.
Do they blow immediately or randomly when the brakes are applied, turn signals activated or horn used?I have a 93 1500 SE that is blowing fuses. The same 2 fuses. they control the horn, radio, turn signals, brake lights, and cruise control from setting. Cruise will still turn on, just not engage. Any suggestions on where to start looking?
In that case I would suspect a short in a bulb or a bulb socket.Ive noticed usually as soon as i use the turn signals. I have not added any accessories to the bike since i bought it
I did notice also that the horn button and the turn signal switch feels"sluggish and Stickey" for lack of a better way to describe it. I think im going to take the botton assembly or control assembly apart and clean it good with contact cleaner and see if that helps.In t
You have a short, not a bad connection. It won't be in the switches.I did notice also that the horn button and the turn signal switch feels"sluggish and Stickey" for lack of a better way to describe it. I think im going to take the botton assembly or control assembly apart and clean it good with contact cleaner and see if that helps.
Can the switches short out ?You have a short, not a bad connection. It won't be in the switches.
I guess it's possible but highly unlikely. The wires from the switches can short against the handlebar where they are clamped into the switch housing by a metal piece.Can the switches short out ?
Its blowing #2 and #10Which fuses blow? Number 1is the top and 2 next down etc.
It is common for the hazard switch to stick on if it has not been used in a long time. I wonder if you do not have an issue with the turn lights and the hazard light switch is stuck on. That would make the #10 fuse blow as well as #2. Try trouble shooting with just the #2 fuse and pull out the #10. I think when you fix the #2 issue and install the #10 fuse you will see the hazards are stuck on. Buy a 15 amp breaker and put it in #2 for troubleshooting. Easier and cheaper than changing the fuses all the time. Remove one turn signal at a time keeping in mind it could be a front or rear. I agree with Dave. The issue is going to be a short at the bulb or not far away.Which fuses blow? Number 1is the top and 2 next down etc.
I took apart the switches and cleaned everything with contact cleaner. Ive also checked all the bulbs with an ohm meter. Right now everything is working. Hopefully it will stay that way.It is common for the hazard switch to stick on if it has not been used in a long time. I wonder if you do not have an issue with the turn lights and the hazard light switch is stuck on. That would make the #10 fuse blow as well as #2. Try trouble shooting with just the #2 fuse and pull out the #10. I think when you fix the #2 issue and install the #10 fuse you will see the hazards are stuck on. Buy a 15 amp breaker and put it in #2 for troubleshooting. Easier and cheaper than changing the fuses all the time. Remove one turn signal at a time keeping in mind it could be a front or rear. I agree with Dave. The issue is going to be a short at the bulb or not far away.
My guess is it is blowing #2 fuse because of the issue. It is back feeding the #10 fuse and blowing it because the hazed is stuck in the on position. Fix the #2 issue then work to free up the sticky hazard switch, All issues will go away including the cruise.
