21 - 29 of 29 Posts
OK< Apparently i have not fixed this problem. Now, the #2 fuse blows as soon as the bike is started. The #10 fuse only blows when i try the blinkers.
That is really odd, the #10 fuse shouldn't have anything to do with the turn signals, only the hazard flashers. #2 on the other hand does a lot of things.
2000 GL1500SE
OK< Apparently i have not fixed this problem. Now, the #2 fuse blows as soon as the bike is started. The #10 fuse only blows when i try the blinkers. I jumped the fuses out to try to force the issue to show itself. Everything works fine except the left blinker and the hazards, or emergency flashers. I have taken off the seat and a good bit of the plastics trying to located the issue, but with no luck. Does anyone have a wiring diagraham in a PDF file they can send me so i have a diagraham? Any help would be appriciated. Thanks.
Here is a color wiring diagram for the 94 1500. Yours will be almost identical.
James McC. I sent you a private message, look at the square with your avatar in it at the top right, there should be a red dot, click on the square and then conversations.
Discussion Starter · #24 ·
i think i found the problem. 2 relays under the trunk have burn holes in them. Hope this is the problem, and not a result of another problem.
1998 GL1500 Asp and 2017 GL1800 4AC
Are they the turn signal flasher relays?
Yes they are. The local Honda shop is trying to see if they have them.
A little searching found that the part number for the relays are 38301-MG9-681 and will set you back about $50 each from Honda.
On eBay, I found a set of two for $12.99 under Item number 184803990723.
Discussion Starter · #28 ·
The Honda shop ordered them for me. About 42 bucks each. I hope this was the problem and not a side affect of a different problem. Thanks for the help and information.
Discussion Starter · #29 ·
Installed the 2 new flashers. Left turn signal wouldnt work, fuses are fine until i hit the hazard button. Blown fuses again. Completely take the bike apart. Finally found the issue. In the upper control box where the hazard swith is located, there is a metal clamp holding a piece of plastic over the solder connections. It had worn thru the plastic and was touching a wire and the screw head was touching the handle bar. small piece of tape and problem is gone. Bike is back together and put about a hundred miles with no issues. 20210520_121630.jpg 20210520_121637.jpg 20210520_121646.jpg 20210520_121656.jpg
21 - 29 of 29 Posts
