Senior Guru
Try downloading the workshop manual from the link in the refence forum, that should have the info. I can't find my own manual to check for you at the moment.
namsgt1946 wrote:
Does anyone know the ohms for a coil on GL1500 1994??? Thanks
Do you want "secondary coil resistance" or "primary coil resistance"? There is a difference.
Secondary is measured through the spark plug caps (each ignition pair).
Primary is measured through the 4-pin white connector behind the right fairing inner cover.
Then there is resistance between the primary terminals on each coil.
If you specify what you want, we can help.
