Okay everybody, I'm not getting fuel flow out of the fuel pump. I checked the leads at the fuel pump. No power. I disconnected the positive lead to the pump, jumped to the battery, and voila! Pump runs. I've checked all the fuses, but not sure which relay to check. I'm not sure if the BAS is the culprit, as the bike runs. (I found that the pump wasn't running as a byproduct of taking the carbs off...) I'm leaning towards the ECU, but not sure how to check it. Any ideas?
Thanks in advance!
Thanks in advance!
