4 am tomorrow morning
NOT!!!!
I would take it for a ride tomorrow morning, lots of stop and go, very gently, lots of idling, with a fewget-up and go jaunts. Remember the idle circuit cuts over to the main jets at ~1200rpm.
Take your cell phone just in case it totally cloggs up and it will not run.
Don't expect this to fix in one shot. You may have to do this several times.
If it does not improve after the 4-5 times, then I would seriously consider pulling the carbs and givng them a very thorough clean/rebuild.
Check all vacumn hoses, and for vacumn leaks.
New air,fuel filter, spark plugs with proper gap, etc
Use fresh gas for this whole project.
On your fuel mileage, use miles from the odometerand gallons from the pump. Do not use the gas guage as they are notoriusly in-accurate.
Fill up to the same level each time.
I would keep a record of gallons used and miles drivenfor a while, something like 10-20 tanks fills.
Then calculate your mileage over that.
Mileage on these bikes is very dependant on takeoff speed (take off like a granny), top speed (less that 70MPH), andtire pressure (~40psi up front, ~41 in back) and riding one-up, shift early (~2000rpm) for maximum mileage.
Keep us posted on your results.
