Check for 12V on the relay coil. The green wire on Relay 3 is ground, the black wire is the 12V supply from fuse #11.I'd check the green wire for continuity to ground and the black wire for 12V. If you don't find 12V on it jump a 12V source to it and see what happens when the relay is forced to energize. If that brings things to life then it's just a matte to trace the 12V wire back through the fuse to it's source.
