Ok first, I have a manual and have tested all ignition components & switchesand they test good. The bike is hard to start, I have to put a spark tester on a plug and keep cycling the starter button till I see fire. The bike will start but choke on only, carbs are clean. It will not idle or accept any throttle. When running you can hear pops through the intake and backfires out the exhaust (cam belts are new). With the spark tester in place you can see the fire come and go. I am leaning toward ecm but have never heard of one going bad, the bike sit in a barn for 7 years and has 67,000 miles on it I cleaned the carbs, fuel tank,petcock and replaced the plugs, air filter and timing beltsrode it 150 miles one day with no problems and the next day it wouldn't run.
Please help.
Paul
Please help.
Paul
