Hi,
First post here after lurking quite a while and learning a lot. I needed a new rear tire so while changing it out I decided to do the maintenance on the drive as well. I just bought the bike a few months ago with 62k miles on it and since have put another 2500 miles on it.
So I pulled the drive and cleaned it up. From the first photo, Is this wear on the inside end? Seems to taper down towards the shaft and it worries me a bit. Other than that, it appears to be in great shape. No wear at all on the u joint end either.
On the second photo, there appears to be water intrusion due to the brown rust greasy substance. There is a liquid on some sort in there as well and almost smells like gear oil. Is there a seal that connects this to the final drive housing?
I have parts coming tomorrow so I can put this all back together, pending that this isn't a new problem.
Thanks so much
Cory
1997 GL1500 SE
Hi,
Thanks so much
Cory
1997 GL1500 SE
