1 - 20 of 53 Posts
Hi all!
Well today was a gorgeous day so I decided to take my GL1500 out for a spin. And wouldn't you know it. The damn thing sometimes jerks or stumbles again under 2,000 RPM. I've been using non-ethanol fuel in it, and she's been great. What's strange is it didn't seem to happen until I took it off its maintenance stand.
I also noticed she doesn't want to start very easily at times. Cold and choke on first setting, it started and then died as though it didn't get enough fuel. Started it a second time and zooom she went. After warning her up, I took her out for a spin and the torque didn't seem as strong as usual. Once I got to 3rd gear, I accelerated a little harder at about 1,600 RPM and the jerks came back. Once above 2,000 RPM, she accelerated normal.
I'm noticing that if I roll the throttle to quickly, that's when she would sometimes jerk. But if I rolled the throttle a little slower, no jerking. I'm wondering if my accelerator pump might be malfunctioning.
If you all recall, I solved the problem last summer after replacing the spark plugs. I'm wondering if it's possible my float needle might be failing during shutdown and leaking fuel into the intake manifold. I say this because sometimes after shutdown, the engine smells flooded and it's difficult to start. Once you get her started, a little puff of smoke (blue) comes out of the left exhaust, and then all is clear. This only happens when the engine smells flooded. Wouldn't this also fowl out the plugs? Perhaps that was the reason why the last plugs failed.
I have a good mind to also check the coil voltage on the right side above the fan. It's a red wire connector and that was corroded last summer. It may have happened again because it's strange that this didn't happen until after I rolled the Wing off of its stand.
Any ideas guys?
Joe
Any ideas guys?
Joe
That's the connector to the kill switch & right handlebar switches which then goes to the ignition. There is another connector to the coils to the right of the air box. I thought you had an ignition problem all along. Cracked coil, bad wire or end cap. I have seen where coolant has leaked on top of the coils and corroded the connections.
Joe,
I agree with Dave. When you accelerate hard the voltage required to fire the plugs really increases. If you find you can gently roll on the throttle and the engine will run up to high RPM but if you hot the accelerator hard and it balks that can be a sign of a weak spark. Could be primary or secondary wiring issues, bad plugs, coil etc.
I re-read your earlier thread, and wonder if you ever Deleted the Fuel Petcock? (as I believe that you should)
Either it may be bad (which is common), and/or it may have a poor vacuum supply operating it (which will cause fuel starvation).
In regards that hard-starting when cold... Try opening the throttle 1/2-1 turn (prior to starting engine), then close, then start as-normal using choke.
I normally only have to do this when the temps are sub-30F... At higher temps, this method may flood the engine.
Discussion Starter #10
LOL You guys are a riot! No "jerking" on my GL1500, figuratively speaking. :grin3: I mean, I love my bike for sure, but not enough to "please" myself. I suppose I could set the cruise on, and that'll free up a hand. :ROFL:
The jerking happens below 2,000 RPM as it is trying to accelerate. I too am convinced that this a ignition/power issue and the plugs are probably not getting enough spark, either from a cracked coil, bad wire(s), or possibly a power source issue. I'll check all of that once I am done with the 1986 restoration. She runs anyways...just have to not accelerate so hard (1/2 throttle) under 2,000 RPM.
As for the seldom difficulty starting, as I indicated earlier, the problem happens after shut down and the bike has been sitting for about 20 minutes. I can smell fuel on the engine, and I believe the left carburetor is leaking fuel into the intake manifold because of a failed float needle. If you all recall, I mistakenly set the floats to 7mm, when they were supposed to be set to 8mm. I never corrected that yet, but that's coming before the Spring. I want to remove the carbs, replace the float needs and set them to 8mm, and while the carbs are off, I'll remove the coils (not sure how that's done on the GL1500; I do not have a manual for that bike), and check all of the wires, caps, and the coils. Hell since they will be off, I might as well replace them.
Any suggestions on a good aftermarket coil for the GL1500? I was unable to find one on EBAY except for a 1989 model. I'm not sure if the coils on an 1989 GL1500 are the same as the 1997 GL1500. And what about plugs wires? Any recommendations?
Joe
big PIA
I have Clymer GL1500 manual that came with my 92 when I bought it. Not sure where you are but I just don't need it sitting around any longer.
big PIA
cost of shipping plus $10.00
Since I went up to 2002 after the 1500 got totaled it is no longer doing me any good. I think I should be on the lookout for a GL1800 repair manual myself
... I can smell fuel on the engine...
When the fuel petcock fails, it sometimes leaks fuel in the Overflow Tray... which perhaps is what you're smelling.
Don't make me strangle you... Just delete the darn fuel petcock, and report back:lash:
Discussion Starter #18
It smells as though the fuel were draining into the left intake manifold. But I can't be sure. I've never noticed any fuel leakage in the service cap collection tray. But I'll take a look next time.
I think it's the left carb float not closing and a little bit of fuel will drain into the manifold after shutdown.
How do I delete the fuel petcock?
Joe
Discussion Starter #19
Discussion Starter #20
Sorry I haven't gotten back to you. Yes I am interested in buying the GL1500 manual. Does it cover 1997 Goldwings? And how shall I purchase this from you? Money Order? PayPal? Ebay? Send me a PM (private message) and I'll PM you the information you might need...or give me a ring...I can PM you my mobile number. How much will shipping cost?
Joe
1 - 20 of 53 Posts
