So I just purchased my first Goldwing and It had some toggle switches installed for the headlight as well as some bogus LED lights. I removed the LED and re soldered all the wires back in hopes it would work without the toggle switch. I was wrong. I'm thinking they added the toggle to bypass a prior issue with the bike. I have 12v at the fuse and when I run power direct to the harness the lights turn on.
The High beam indicator has never worked and I'm leaning toward either the ground is faulty or possibly the hi/low beam switch? Any insight or links to some walkthroughs on the handlebar controls would be greatly appreciated. Thanks everyone!
