1999 engine guards work on a 1993 model. Will they line up for mounting. Any help in this would be appreciated. Thanks in advance
I recently was swapping the guards from a 95 to a 99 and the guards from the 99 to the 95. The guards from the 99 did fit on the 95 but when I tried the other way it was a no fit situation. I do not know if the 93 is the same as the 95 but I think it is.
Thank you so much the part numbers for 95 and 93 were the same so I believe that the 99 should then work for me since they worked on your 95. Thanks again
Good luck with the swap.
